atkAudio Plugin
atkAudio Plugin 0.32.2
Guys, when i load a Guitar Plugin (Amp Sim from Neural DSP) the latency is HUGE. However, if I open the standalone plugin (without OBS) with the same settings, Buffer size 192, it sounds great. Only when I load it from OBS does it have latency.
If you're monitoring through OBS audio, then yes, it introduces extra latency.
Amazing plugin! However, I’ve encountered a bug on my Mac Ultra M2 running macOS Tahoe 26.0.1. It seems to break some right-click functionalities — for example, when I try to change a plugin in another VST, I can’t select any plugin at all. Similarly, when I open the microphone properties and try to switch between “Monitor” and “Output,” the right-click options don’t respond. In short, it disables the ability to use right-click to access certain properties. If you could fix that, it would be perfect!
Is there a way to completely uninstall any atk related programs/files from my Mac? I searched in my Mac fsystem for any atk files and deleted them, but in OBS atk still appears.
I want to uninstall it because ever since I installed atk, OBS audio monitoring drop down menu is broken and not switchable no matter what.
This should be fixed in just released update 0.25.4. Under macOS the plugin is installed in userhome/Library/Application Support/obs-studio/plugins.
Came with v0.25 update
Hey man, there is still crackling, cutting in the sound - sample rates problem... AND the audio buffer size....strange is as increasing the buffer size more cracking the sound becomes - normal is vice versa :) and even more strange is that, when I play a VIDEO file and output the sound true your plugin everything is great BUT if I do the same with an audio file - full of crackling and cutting.
The same with MacBook , Mac mini - MacOS 15.7.1, OBS - latest, USB Audio interface SSL 12
In version 0.25.5? What device type and buffer size?
Mac OS - core audio - as I mention before its an USB Audio interface - "SSL 12"
And just to clarify that this happens with file based sources? Just testing, and 'live' source like audio input seems ok. But file based sources have buffering issues.
live audio - works great, videos - no issue at all (can't hear the audio popping) , audio files are the issue - tested mp3 and m4a ...all the same,no matter of sample rate , buffer size.
