Plugin loading failed
digitahl
Hi, I didn't use for about 2 years Obs anymore. Now I upgraded to the latest version of Obs for my MacBook Pro 2019 with Tahoe 26.1
Now every time when I open Obs I get the attached message that the sown plugins have to be updated or deleted. I deleted OBS completely from my my ( obviously not 100% ) . I went to finder- library- application support - and deleted here the Obs folder. , deleted then the trash folder and rebooted my Mac. installed latest Obs version , installed it a still the same message. Is there anyone who can help? thanks
Probably missed the right folder. OBS stores plugins at ~/Library/Application Support/obs-studio/plugins/ — note it's all lowercase with a hyphen, not 'OBS Studio' or 'Obs'. In Finder hit Cmd+Shift+G, paste that path, and delete everything inside. That usually clears leftover plugin stubs even after a reinstall.
I am having the same issue as OP. I uninstalled and erased all folders for elgato stream deck and OBS/OBS studio-- followed your instructions above. rebooted and downloaded OBS and Stream Deck and still having the same issue. even with the plugin deleted from the plugins folder, still getting the notification. Can anyone help?
