Question / Help many pixels and low quality with 5000k bitrate help :(
Siebakk
Hello
please read pinned posts they say provide a logfile
https://obsproject.com/forum/threads/please-post-a-log-with-your-issue-heres-how.23074/
Please try to include a recording/streaming session when you experience problems while streaming or recording,
as OBS only writes important performance data during recording or streaming sessions.
If you have solved your problem yourself, please let the others know how you did it If someone else has the same problem,
he will find your post, read it through, is no step closer to solving it, and has wasted some time.
19:46:21.645: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 14134 (12.1%)
19:46:21.645: Output 'adv_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 1043 (0.9%)
19:46:21.645: Video stopped, number of skipped frames due to encoding lag: 14139/116256 (12.2%)
lower your output resolution your encoder/cpu cant keep up
