Free Animated Lower Thirds with Dockable Control Panel v.1.6
Hi I have the 1.6_V2 installed from here but I cant get it to go blue, the Master controller goes Blue but the individual ones go red when switched on?
Dear akimba,
Please verify that your browser-source.html source is configured as follows:
  1. Make sure “Local file” is unchecked.
  2. If you are using Windows, the URL should look similar to this:
    file:///C:/Program%20Files/obs-studio/Animated-Lower-Thirds-Fixed/lower%20thirds/browser-source.html
This is important because the plugin folder must be located inside your OBS installation directory.
Regards
