Status
Not open for further replies.
I cant stream at 1080p@60fps with presset on quality with AMD rx580 8gb is it normal? or im doing something wrong? it overloads and looks choppy, if this is normal now my question is whats gives more quality? 720p@quality presset? or 1080p with balanced presset? also i noticed that for example 3k bitrate with AMF looks worse than 3k with CPU encoding, but it gets better with 5-6k bitrate, my other question is what is a good bitrate between image quality and low internet speed of viewers? im currently using 6k which is the max for twitch, should i keep it?
I have bouht an new laptop for streaming church services with OBS. These are the specs:
Dell Inspiron 13 5000 Series - 5370
8th Generation Intel Core i7 Processor Label
AMD Radeon 530 Graphics with 2G GDDR5 graphics memory
This GPU is listed here: https://www.amd.com/en/products/graphics/radeon-530
It supports Video Code Engine (VCE)
My question is: Is this plugin mandatory to use because of mu AMD GPU? Or will I be able to just select this GPU in the encoder without using this plugin?
I choose a laptop with a dedicated GPU so OBS can run smoothly. I stream the projected screen @ 1280x720 30fps. Nothing fancy, bitrate of 1mbit is enough.
Edit: I just read that this plugin is included in OBS Studio: I will install OBS Studio and find out if the AMD GPU can be used 'out of the box' for encoding.
Hello I am trying to stream on amd 2200g. I can select AMD hardware encoder but when i start streaming encoder will fail to stream and the only option left is software encoder. Is my apu supported for streaming using amf?
I'm having a bit of an issue when trying to record or stream while using the plug-in. I just upgraded my motherboard from am h110m to a z270 series.
CPU: i5-6600k @ 4.5 GHz
GPU: RX480
Mobo: ASrock Fatal1ty Z270 Gaming-ITX/ac
Whenever I press record or stream it immediately crashes, saves a crash report, and OBS then refuses to close even when attempting to close via task manager. I didn't have this issue before with the older motherboard, but I've reinstalled windows since then so I imagine that there has been something that I've changed or forgot somewhere. Any ideas?
GPU: RX480
Nevermind! I did a clean install of the AMD drivers and now it works flawlessly again. Sorry for the bother, haha.
Ok figured out a problem when using the plugin. Whenever I try to record/stream any video in 720p (scaled down from 1080p through video and output tab) I get an error. Stream and recording works just fine when selecting 1080p as output resolution. Can anyone help me with that? I cant stream at 1080p, its impossible with my Bitrate.
I'm on a Radeon R7 240, and it looks like it's just baaaaaarely behind the supported cards, I really can't afford shilling out a hundo big ones for a new card, so it'd be really cool if you were to add support for this little thing.
@TheGamerGuy500 , the VCE is not included in your model of the video card.
(look for R7 200 Series Specs table)
https://www.amd.com/en-us/products/graphics/desktop/r7
More over,
https://github.com/obsproject/obs-amd-encoder/wiki/hardware-support#other-information said:
The plugin requires that your AMD GPU or APU has support for the Video Coding Engine (at least Version 1.0) in addition to always requiring the latest (not the recommended) driver...
plugin just uses all that available in your PC. Obviously, there is nothing it can add itself.
i have a problem where OBS doesnt let me record on any other encoder/settings except when its on lossless resulting in extremely large file size.
i created a thread in general section but i was told to post here .
i am getting - an unspecified error while recording error
my gfx drivers are latest
i uninstalled /reinstalled obs
changed my recording path
still stuck with this error
i have tried all the possible combination of video recording settings + encoders but it still doesnt let me record except when i keep the recording quality to lossless resulting in file size of 100s gb
here is a pastbin link of my log : https://pastebin.com/UVTjLh1U
please help
then why does it work when its on lossless quality ?
i can record on lossless quality just fine but it doesnt let me record using any other encoder. throws this unspecified error .
Help me.. i use 2200G, but when i'm trying to record with H265 HEVC in recording tab, there is a pop up "unspecific error" .. here is my log file.. help me ti fix this :(
08:34:12.467: CPU Name: AMD Ryzen 3 2200G with Radeon Vega Graphics
08:34:12.467: CPU Speed: 3493MHz
08:34:12.467: Physical Cores: 4, Logical Cores: 4
08:34:12.467: Physical Memory: 6073MB Total, 1764MB Free
08:34:12.467: Windows Version: 10.0 Build 17763 (revision: 194; 64-bit)
08:34:12.467: Running as administrator: false
08:34:12.467: Aero is Enabled (Aero is always on for windows 8 and above)
08:34:12.468: Windows 10 Gaming Features:
08:34:12.468:     Game Bar: On
08:34:12.468:     Game DVR: On
08:34:12.468:     Game DVR Background Recording: Off
08:34:12.474: Sec. Software Status:
08:34:12.478:     Windows Defender Antivirus: disabled (AV)
08:34:12.478:     AVG Antivirus: enabled (AV)
08:34:12.479:     Windows Firewall: enabled (FW)
08:34:12.479:     Windows Defender Antivirus: disabled (ASW)
08:34:12.479:     AVG Antivirus: enabled (ASW)
08:34:12.480: Browser Hardware Acceleration: true
08:34:12.480: Portable mode: false
08:34:12.691: OBS 22.0.2 (64-bit, windows)
08:34:12.691: ---------------------------------
08:34:12.710: ---------------------------------
08:34:12.710: audio settings reset:
08:34:12.710:     samples per sec: 44100
08:34:12.710:     speakers:        2
08:34:12.712: ---------------------------------
08:34:12.712: Initializing D3D11...
08:34:12.712: Available Video Adapters:
08:34:12.716:     Adapter 1: AMD Radeon(TM) Vega 8 Graphics
08:34:12.716:       Dedicated VRAM: 2131623936
08:34:12.716:       Shared VRAM:    3184353280
08:34:12.716:       output 1: pos={0, 0}, size={1366, 768}, attached=true
08:34:12.726: Loading up D3D11 on adapter AMD Radeon(TM) Vega 8 Graphics (0)
08:34:12.749: D3D11 loaded successfully, feature level used: 45056
08:34:13.956: ---------------------------------
08:34:13.956: video settings reset:
08:34:13.956:     base resolution:   1280x720
08:34:13.956:     output resolution: 1280x720
08:34:13.956:     downscale filter:  Bicubic
08:34:13.956:     fps:               60/1
08:34:13.956:     format:            NV12
08:34:13.956:     YUV mode:          601/Partial
08:34:13.958: Audio monitoring device:
08:34:13.958:     name: Default
08:34:13.958:     id: default
08:34:13.959: ---------------------------------
08:34:13.963: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
08:34:13.967: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
08:34:14.370: [AMF] Version 2.5.0 loaded (Compiled: 1.4.9.0, Runtime: 1.4.11.0, Library: 1;4;11;0;18.50;201812061932;CL#1717373).
08:34:14.468: [AMF] [Capability Manager] Testing Direct3D 11 Adapter 'AMD Radeon(TM) Vega 8 Graphics (VEN_1002/DEV_15dd/SUB_15dd1002/REV_00c8)':
08:34:14.468:   H264/AVC: Supported
08:34:14.468:   H265/HEVC: Supported
08:34:14.468:
08:34:14.545: [AMF] [Capability Manager] Testing Direct3D 9 Adapter 'AMD Radeon(TM) Vega 8 Graphics [\\.\DISPLAY1] (VEN_1002/DEV_15dd/SUB_15dd1002/REV_00c8)':
08:34:14.545:   H264/AVC: Supported
08:34:14.545:   H265/HEVC: Supported
08:34:14.545:
08:34:14.585: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
08:34:14.586: LoadLibrary failed for '../../obs-plugins/64bit/libEGL.dll': The specified procedure could not be found.
08:34:14.586:  (127)
08:34:14.586: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
08:34:14.587: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
08:34:14.591: [obs-browser]: Version 2.1.5
08:34:14.604: LoadLibrary failed for 'nvEncodeAPI64.dll': The specified module could not be found.
08:34:14.604:  (126)
08:34:14.841: Couldn't find VLC installation, VLC video source disabled
08:34:14.851: No blackmagic support
08:34:14.863: ---------------------------------
08:34:14.863:   Loaded Modules:
08:34:14.863:     win-wasapi.dll
08:34:14.863:     win-mf.dll
08:34:14.863:     win-dshow.dll
08:34:14.863:     win-decklink.dll
08:34:14.863:     win-capture.dll
08:34:14.863:     vlc-video.dll
08:34:14.863:     text-freetype2.dll
08:34:14.863:     rtmp-services.dll
08:34:14.863:     obs-x264.dll
08:34:14.863:     obs-vst.dll
08:34:14.863:     obs-transitions.dll
08:34:14.863:     obs-text.dll
08:34:14.863:     obs-qsv11.dll
08:34:14.863:     obs-outputs.dll
08:34:14.863:     obs-filters.dll
08:34:14.863:     obs-ffmpeg.dll
08:34:14.863:     obs-browser.dll
08:34:14.863:     image-source.dll
08:34:14.863:     frontend-tools.dll
08:34:14.863:     enc-amf.dll
08:34:14.863:     coreaudio-encoder.dll
08:34:14.864: ==== Startup complete ===============================================
08:34:14.872: All scene data cleared
08:34:14.872: ------------------------------------------------
08:34:14.965: WASAPI: Device 'Speakers (Realtek High Definition Audio)' initialized
08:34:15.013: WASAPI: Device 'Microphone (HD Webcam C270)' initialized
08:34:15.043: [window-capture: 'Window Capture 2'] update settings:
08:34:15.043:     executable: ApowerMirror.exe
08:34:15.055: warning: deprecated pixel format used, make sure you did set range correctly
08:34:15.066: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
08:34:15.098: Switched to scene 'MIX'
08:34:15.098: ------------------------------------------------
08:34:15.098: Loaded scenes:
08:34:15.098: - scene 'START':
08:34:15.098:     - source: 'Image' (image_source)
08:34:15.098: - scene 'MIX':
08:34:15.098:     - source: 'Window Capture 2' (window_capture)
08:34:15.098:     - source: 'Video Capture Device' (dshow_input)
08:34:15.098:         - filter: 'Color Correction' (color_filter)
08:34:15.098:     - source: 'alert' (browser_source)
08:34:15.098:     - source: 'chat' (browser_source)
08:34:15.098:     - source: 'goal' (browser_source)
08:34:15.098:     - source: 'Image 2' (image_source)
08:34:15.297: CalculateFileHash: Failed to open file 'C:\Users\Mpii-TV\AppData\Roaming\obs-studio\updates\whatsnew.json':
08:34:37.460: Settings changed (outputs)
08:34:37.461: ------------------------------------------------
08:34:39.013: [AMF] [H265]<Id: 10> Encoder Parameters:
08:34:39.013: [AMF] [H265]<Id: 10>   Backend:
08:34:39.013: [AMF] [H265]<Id: 10>     Video API: Direct3D 11
08:34:39.013: [AMF] [H265]<Id: 10>     Video Adapter: AMD Radeon(TM) Vega 8 Graphics (VEN_1002/DEV_15dd/SUB_15dd1002/REV_00c8)
08:34:39.013: [AMF] [H265]<Id: 10>     OpenCL: Not Supported
08:34:39.013: [AMF] [H265]<Id: 10>       Transfer: Disabled
08:34:39.013: [AMF] [H265]<Id: 10>       Conversion: Disabled
08:34:39.013: [AMF] [H265]<Id: 10>     Multi-Threading: Disabled
08:34:39.013: [AMF] [H265]<Id: 10>     Queue Size: 8
08:34:39.013: [AMF] [H265]<Id: 10>   Frame:
08:34:39.013: [AMF] [H265]<Id: 10>     Format: NV12 601 Partial
08:34:39.013: [AMF] [H265]<Id: 10>     Resolution: 1280x720
08:34:39.013: [AMF] [H265]<Id: 10>     Frame Rate: 60/1
08:34:39.013: [AMF] [H265]<Id: 10>     Aspect Ratio: 1:1
08:34:39.013: [AMF] [H265]<Id: 10>   Static:
08:34:39.013: [AMF] [H265]<Id: 10>     Usage: Transcoding
08:34:39.013: [AMF] [H265]<Id: 10>     Quality Preset: Balanced
08:34:39.013: [AMF] [H265]<Id: 10>     Profile: Main 4.0
08:34:39.013: [AMF] [H265]<Id: 10>     Tier: Main
08:34:39.013: [AMF] [H265]<Id: 10>     Coding Type: Automatic
08:34:39.013: [AMF] [H265]<Id: 10>     Max. Reference Frames: 1
08:34:39.013: [AMF] [H265]<Id: 10>     Max. Long-Term Reference Frames: 0
08:34:39.013: [AMF] [H265]<Id: 10>   Rate Control:
08:34:39.013: [AMF] [H265]<Id: 10>     Method: Constant Bitrate
08:34:39.013: [AMF] [H265]<Id: 10>     Pre-Pass Mode: Disabled
08:34:39.013: [AMF] [H265]<Id: 10>     QP:
08:34:39.013: [AMF] [H265]<Id: 10>       Ranges:
08:34:39.013: [AMF] [H265]<Id: 10>         I-Frame: 18 - 51
08:34:39.013: [AMF] [H265]<Id: 10>         P-Frame: 18 - 51
08:34:39.013: [AMF] [H265]<Id: 10>       Fixed:
08:34:39.013: [AMF] [H265]<Id: 10>         I-Frame: 26
08:34:39.013: [AMF] [H265]<Id: 10>         P-Frame: 26
08:34:39.014: [AMF] [H265]<Id: 10>     Bitrate:
08:34:39.014: [AMF] [H265]<Id: 10>       Target: 3500000 bit/s
08:34:39.014: [AMF] [H265]<Id: 10>       Peak: 3500000 bit/s
08:34:39.014: [AMF] [H265]<Id: 10>     Flags:
08:34:39.014: [AMF] [H265]<Id: 10>       Filler Data: Enabled
08:34:39.014: [AMF] [H265]<Id: 10>       Frame Skipping: Disabled
08:34:39.014: [AMF] [H265]<Id: 10>         Period: 0 Frames
08:34:39.014: [AMF] [H265]<Id: 10>         Behaviour: Skip every Nth frame
08:34:39.014: [AMF] [H265]<Id: 10>       Variance Based Adaptive Quantization: Disabled
08:34:39.014: [AMF] [H265]<Id: 10>       Enforce Hypothetical Reference Decoder: Enabled
08:34:39.014: [AMF] [H265]<Id: 10>     Video Buffering Verfier:
08:34:39.014: [AMF] [H265]<Id: 10>       Buffer Size: 20000000 bits
08:34:39.014: [AMF] [H265]<Id: 10>       Initial Fullness: 100 %
08:34:39.014: [AMF] [H265]<Id: 10>     Max. Access Unit Size: 0
08:34:39.014: [AMF] [H265]<Id: 10>   Picture Control:
08:34:39.014: [AMF] [H265]<Id: 10>       IDR: 2 GOPs
08:34:39.014: [AMF] [H265]<Id: 10>       I: 0 Frames
08:34:39.014: [AMF] [H265]<Id: 10>       P: 0 Frames
08:34:39.014: [AMF] [H265]<Id: 10>       B: 0 Frames
08:34:39.014: [AMF] [H265]<Id: 10>     GOP:
08:34:39.014: [AMF] [H265]<Id: 10>       Type: Fixed
08:34:39.014: [AMF] [H265]<Id: 10>       Size: 60
08:34:39.014: [AMF] [H265]<Id: 10>       Size Range: 0 - 16
08:34:39.014: [AMF] [H265]<Id: 10>       Alignment: Enabled
08:34:39.014: [AMF] [H265]<Id: 10>     Deblocking Filter: Enabled
08:34:39.014: [AMF] [H265]<Id: 10>     Motion Estimation: Quarter, Half
08:34:39.014: [AMF] [H265]<Id: 10>   Experimental:
08:34:39.014: [AMF] [H265]<Id: 10>     Input Queue: 16
08:34:39.014: ---------------------------------
08:34:39.014: [FFmpeg aac encoder: 'Track1'] bitrate: 160, channels: 2, channel_layout: 3
08:34:39.014:
08:34:39.028: ==== Recording Start ===============================================
08:34:39.028: [ffmpeg muxer: 'adv_file_output'] Writing file 'C:/Users/Mpii-TV/Videos/2018-12-15 08-34-38.flv'...
08:34:39.230: [AMF] <Id: 10> Initial Frame Latency is 129762700 nanoseconds.
08:34:40.236: [ffmpeg muxer: 'adv_file_output'] os_process_pipe_write for packet data failed
08:34:40.237: [ffmpeg muxer: 'adv_file_output'] Output of file 'C:/Users/Mpii-TV/Videos/2018-12-15 08-34-38.flv' stopped
08:34:40.237: Output 'adv_file_output': stopping
08:34:40.237: Output 'adv_file_output': Total frames output: 1
08:34:40.237: Output 'adv_file_output': Total drawn frames: 72
08:34:40.238: ==== Recording Stop ================================================
Hello i have Ryzen 3 2200g with Vega 8 iGpu.
I am using amd encoder 2.3.3 and the encoders above this version are not working.
It gives an error
Xaymar updated AMD Advanced Media Framework Encoder Plugin for OBS Studio with a new update entry:
2.5.1 - Support for Driver 19.x on AMD Vega
The 19.x Driver started enforcing additional restrictions, which seem to only apply to AMD Vega GPUs and APUs. Due to this, the plugin would fail to properly initialize the encoder and users would have to manually set some options.
With this patch, this is no longer necessary. The encoder options are now applied correctly and should no longer cause any issues. Additionally a bug was fixed for Automatic Profile Level which caused it to occasionally select an unsupported Profile Level...
The above release fixes the issues with Ryzen # xxxxG APUs that have an integrated Vega GPU. Please try that version @Anilabha .
FLV does not support H265, use another container like Matroska/MKV.
Status
