Aitum Vertical
Aitum Vertical 1.6.3
Shame on Me! using this briliant plugin years but cannot install it to multiple instances. EXE is going only to the main directory.
Anyone, please support how to install Aitum Vertical to the multiple OBSs locations. Thanks!
First of all, don't get it from their website. Instead, get it from their GitHub as they also have ZIP files for portable installs.
You can get the latest as of this writing for multiple platforms and installation methods from here.
The link is here:
Hope this helps.
--Katt. =^.^=
hello i have a problem, i'm tryng to record while streaming whit this and for some reason my vertical scene that only has my game capture as source will always record my mic even if it's not there, i want to record a clean gameplay without my microphone and stream with my mic at the same time.
Am I missing an option somewhere to use the vertical portion in studio mode? I sometimes find myself editing the presentation while presenting at times and this is helpful for me on the horizontal side of things. Thanks in advance AMAZING Plugin.
Can ANYBODY help me with Aitum vertical plugin ? Why does it shown in Horizontal position .. I am loosing my mind after 3 hours of ĺooking for the answer .......
your canvas is vertical, you will need to make your sources fit within the canvas
Has anyone had trouble installing Aitum Vertical on Mac? I have been trying to install Aitum Vertical and during the install process I always encounter an error. I am on the Apple Silicon Chip Set.
Do you know if there's a way to link the scene transitions in a similar fashion? I have my horizontal and vertical scenes linked the way I want. I also want to be able to link the transition effects so they are the same both vertically & horizontally when switching scenes. Thanks in advance for your help.
Hey mate.
Did you have any success with your query? I’ve got the exact same issue.
Accepting that transitions are not linked (from main scenes to vertical scenes), I thought to myself, ‘ill just re-create the transition using the ‘Vertical Scene Transitions’ found in the Docks menu.
Sadly, my experience is that, although I can apply a Vertical Move transition, it applies it to all Vertical scenes. When I attempt to use a Transition Override (on the Vertical scene), when I select another transition type or transition duration, it does not apply (it’s almost like the buttons don’t work). Also interesting, there is no default ‘duration’ field in the Vertical Scene Transitions Dock like there is with the regular Scene Transitions Dock.
I found this is still the problem whether or not the vertical scenes are linked to the main scenes.
I’d be forever grateful if someone can help me out asap?
Cheers
Hey together,
I'm using the vertical plugin to stream tiktok dart playing live videos.
My problem is that I'm using webhooks to change the scenes of my horizontal default scene.
Is there a way to trigger the vertical scenes via webkoos?
Thank you.
Cheers
Hey mate.
Cheers
No resolution to this issue so far. Hopefully in future updates? We will see I guess.
I haven't been able to figure out a good work around either. I tried the same thing as you did with the override, had the same experience. If you figure something out please let me know. Thanks.
Hey together,
Thank you.
Cheers
Okay, just saw that my issue should be solved by linking main with vertical scenes
I have a problem with the encoder while using the Vertical Plugin to stream on TikTok and Twitch at the same time. The TikTok live just freezes and I can't stop the virtual camera at all, so I have to restart OBS and stop the stream on Twitch. Here's the log file: https://obsproject.com/logs/fpM13NFw76CqFtDc
On TikTok live studio I'm using AMD H265. Please help.
I find a 100% crash caused by vertical-canvas, please confirm.
ENV:
OBS 31.0.3
vertical-canvas 1.5.2
steps:
1. run obs, show vertical scene and vertical sources,
2. add a scene source into vertical scene, then delete this source
3. click top menu named "Scene Collection" and choose "New", switch to a new created scene collection
4. OBS crashed
When adding sources to a vertical canvas, I have more image objects that fit in the single screen when I click Add>Image>. There doesn't seem to be a scroll option - is there any other way of adding them? (I.E. I have images from A-Z but can only see a list of those A-P).
I could just create another source, but that seems like a poor approach on my part.
I can't connect to Instagram after I updated both obs and vertical plugin. I put the Instagram link and stream key, but nothing shows up on the Instagram preview screen. Can someone help me?
Same Issue I updated to OBS 31,1,0 B2 and I can't stream to IG. It was working fine. I also have enhanced broadcasting mode on for Twitch.
If I use restream IG works so its OBS or the Aitum Plugin
